Got the new carburetor today just one question is stuck in my craw right now.
Will my pre bent metal fuel line connect to this with minimal hassle? Or should I plan on this not being bolt and go?
Looks like everything else is compatible... so far...
Not sure, but it looks like the kick down linkage was boxed with it too... I took my rod out years ago...
Got my new Holley Carburetor today
- 72bumbee
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
- colnago
Re: Got my new Holley Carburetor today
You'll have to make some measurements to see if the pre-bent line will fit. I have an Edelbrock 1405, and there are kits that bring out a line that's 3/8", but my fuel pump is 5/16". For now, I'm using a rubber line from pump to carb. So far, no leaks. One of these days, I want a real, metal line.
On the kick-down lever, I never had one, and never missed it. Again, one of these days ... maybe.
- 72bumbee
Thanks again, I’ll most likely just go with rubber if mine won’t reach
Mark Twain
Mark Twain
