I am having issues finding a fuel line for my 1966 F100 that goes from the fuel pump to the carburetor.
Someone has swapped my truck with a 300 six from a 1975 F series truck. The truck the motor came out of had a rear tank, my truck has a behind seat tank. The engine has the rear tank pump with no fuel filter, I bought a new pump correct for my truck with a fuel filter built in. So I need to purchase a fuel line for this style of pump.
Does anyone have a lead on where I could buy this line premade? Thanks!
Trouble finding fuel line for 1966 F100
- colnago
Re: Trouble finding fuel line for 1966 F100
LMC has one for '61 - '64. Will this work? If not, can you bend your own? I'm currently using a rubber line on my '67. Not optimal, but a replacement is further down on the priority list, and the rubber hose keeps her on the road.
