kick back linkage
kick back linkage
I rebuilt engine, new carb and quick fuel carb (600), had tranny rebuilt. Hooking up linkage the kick back linkage is about 1.5" too short. I talked with tranny builder and all seems fine on his end. I measured old intake vs new one and it's almost identical measurements. I even purchased from Holley and extension for the kick back linkage, does anyone have and idea what's up? any and all suggestions will be appreciated.
- colnago
Re: kick back linkage
The only thing that comes to mind is if you are now using a spacer under the carb. I thought that the kickdown lever at the tranny might be upside-down or backward, but I think the lever is connected to the kickdown rod, so it can't be wrong. Personally, I don't have a kickdown installed, and haven't really missed it.
- BobbyFord
You went from 2 BBL to 4 BBL?
According to b4 and after pics the kick down lever is real close or exact to original location. The only thing that might be different is the rebuilder put a new shift kit in the trans when rebuilding. Please help.
- BobbyFord
Shift kit is not going to affect the kickdown lever position on the side of the trans.70xlt wrote:According to b4 and after pics the kick down lever is real close or exact to original location. The only thing that might be different is the rebuilder put a new shift kit in the trans when rebuilding. Please help.
Did you switch from 2 barrel carb to a 4 barrel?
When you say intakes measure the same, I'm wondering what measurements you're talking about.
Of course the overall width and length are the same...they're on the same engine. Maybe the carb is in the same location, front to back and side to side. But: Did you measure the carb pad height from the china wall?
- colnago
Also, even if the intake measurements are the same, just the fact that you replaced the intake can be some of the difference. You used new gaskets, which may be holding the new intake higher. Maybe the new intake sits a fraction of an inch further forward on the block.
Final suggestion: take the kickdown lever to a machinist or welder, and have them extend the length another 1-1/2". It's not uncommon for the kickdown lever to be too short when converting from 2BBL to 4BBL (hence, BobbyFord's question).
- BobbyFord
If you went from a 2 barrel carburetor to a 4 barrel carburetor that is why the kickdown rod is “too short.”
Just get a cable setup from lokar. That's what I had, works great. Problem solved.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- colnago
That will work on our bumps? I thought Lokar only worked on later models.Bill Ramsey wrote:Just get a cable setup from lokar. That's what I had, works great. Problem solved.
I'm here to tell you I bought one, installed it and it worked. It's not working now, I yanked the engine out.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
