new radiator burping and timing
1guydude
Post by 1guydude »
K so I got a new radiator in today. Do I just start the motor with the cap off the radiator. Let it run till hot and turn it off? fill up and continue to do this until the level inside the radiator stays the same?! Thanks
also can someone run me through the timing process? I got the light but need to watch some videos and do some reading. I want this thing timed so that can be eliminated from it running to hot. Hoping these two will keep my motor cooler.
thanks all
-devin
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
71Fe2O3
Re: new radiator burping and timing
Post by 71Fe2O3 »
Fill the radiator with coolant, start the engine with the cap off, add more coolant as the level drops, then put on the cap. After it cools down, perhaps the next day or when you have time, remove the cap and top it off. An overflow container is also a good idea if you don't have one already-I use a 1 liter soda bottle.
With regard to timing, get the light and follow the directions. Make sure the vacuum line to the distributor vacuum advance module is disconnected from the distributor and plugged. These engines run well when timing is advanced several degrees-I think mine is around 10 degrees before TDC-most folks on here seem to use between 7 and 12, some higher-listen to the engine and you will know. I found it helpful to put white chalk on the timing marks on the harmonic balancer for better visibility.
If you have a points ignition, consider adjusting the dwell angle so you can get the best spark.
Fred
1guydude
Post by 1guydude »
K thanks for the respone fred. Hopefully ill get both these figured tomorrow or monday before work.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
HIO Silver
Post by HIO Silver »
Drill a 1/8-inch hole on the t-stat's flange and orient at 12 o'clock... doesn't matter if it is AM or PM... doing so will bleed air from the block and in turn bleed air out of the entire system.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
1guydude
Post by 1guydude »
drilling a small hole in the thermostat or side of it was recommended to me by another as well. Im probably gonna do this.
Thinking I might have my head gaskets or one of em on incorrectly. I wasn't aware of the water passages be closed on the front and open on the back nor do I remember how I placed em.
Getting new gasket set and tearing it apart... :/
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
