It.dosent need to be done, but probably will need to be done in the near to not so distant future.
Ive done some research and it looks like i will have to take out my motor mount bolts and raise my.motor to get out the pan and such.
I will use 2×4s and wedge it up. My question is. Do i need to unhook my tranny anywhere? Or can i just go at it and everything will angle up with the motor?
Basically im looking at changing my oil pan gasket, pickup gaskets, and clean the.screen.
D
Oil pan gasket
Oil pan gasket
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Re: Oil pan gasket
Truck is a 67' f100 with 390 and c6
Thanks!
Thanks!
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- colnago
Re: Oil pan gasket
I think you'll be okay, but you should lossen or remove the rear mounting bolts on the tranny, since it will need to tilt up. Other than that, the U-joint should protect the driveshaft.
