Trouble Mating 390 and C6
Cal2121
Post by Cal2121 »
I am in the process of putting my rebuilt 390 back in my truck. I did not remove the C6 when I pulled the old engine. I have the engine back in with the flexplate bolted to the torque converter. But, I cannot get the transmission housing to fully mate with the engine block. It's about 1.5 inches away. Any ideas on the likely culprit? I've tried messing with the height and pressure on the trans and engine to no avail. Any help is greatly appreciated.
Busboy
Re: Trouble Mating 390 and C6
Post by Busboy »
Are you sure the t.c. is all the way into the trans ?
1967 F-100 4x4 custom cab.
Cal2121
Post by Cal2121 »
I'm not 100% sure. How can I tell for sure? The trans looks like it needs to come forward a bit for the trans mount to align with the cross member. I removed the trans cross member to make it easier to move things awound
tnlprt
Post by tnlprt »
The torque convertor should not be bolted to the automatic flywheel UNTIL the transmission and engine is bolted together.
Unbolt the torque convertor
Move the engine out of the way and secure it from moving
Place the torque convertor on the input shaft of the trans
http://diyford.com/install-ford-c4-c6-t ... step-step/
Jacksdad
Post by Jacksdad »
What tnlprt said. You bolt the torque converter to the flex plate after the engine and trans are together. While it's apart, I would check that the drive hub on the converter didn't damage the pump seal.
Cal2121
Post by Cal2121 »
Got it. Thank you very much. Hoping I didn't damage anything! Really appreciate your help.
Jacksdad
Post by Jacksdad »
:thup:
Cal2121
Post by Cal2121 »
Update: I was able to get in there and look. Everything looks okay, and I was able to get the TC properly seated. Now to connect them and get the other items put back on the engine. I can't wait! Thanks again.
