Shifter popping out
ahgrafx
Shifter popping out
Post by ahgrafx »
Since I don't have a choice I don't know exactly what Hardware is supposed to be in place to keep the shifter stick in place it pulls right out has a couple Dome pieces on top of a spring that just pulls right out of the hole any diagrams or suggestions to fix this would be greatly appreciated and where everyone gets their Chilton's cuz it doesn't seem to be for sale at any auto store locally thanks
71Fe2O3
Re: Shifter popping out
Post by 71Fe2O3 »
Some more information, and pictures, might help you to get some advice.
I doubt they sell Chiltons or Haynes manuals for these trucks any more. I have one, bought used from an eBay seller, and it is not terribly useful.
The best manual as far as I know is the Ford shop manual, which you can find in electronic form at the following website.
https://www.hipoparts.com/1964-72-ford- ... atalog-cd/
It has wiring diagrams and also expanded diagrams of every system on the truck.
You can also find many relevant diagrams on this site. Find the expanded diagram, puzzle over it until you figure out what you are looking at, zoom in on it to find the parts, and then do google searches on the part numbers.
Fred
eggman918
Post by eggman918 »
7220 is what holds it in it pushes down on the domed piece and spring and twists ~15* and locke on to the two pins
http://www.fordification.com/tech/image ... rshift.jpg
colnago
Post by colnago »
More info needed. What tranny are you talking about?
ahgrafx
Post by ahgrafx »
eggman918 wrote:7220 is what holds it in it pushes down on the domed piece and spring and twists ~15* and locke on to the two pins
exactly what I needed thanks eggman918!
is this a part i will need to get at a salvage yard or are there new ones made?
thanks everyone
eggman918
Post by eggman918 »
Boneyard,Ford and Dodge both used the 435 and the shift towers should be the same. :wink:
