My truck: '72 F250 2WD WITH dual fuel tanks!
Is there anyway to run dual exhaust WITHOUT getting in the way of the transmission????
Any dual exhaust set up pics are appreciated guys!!
Thanks all
DUAL EXHAUST QUESTION '72 F250 2WD
- Ranchero50
Re: DUAL EXHAUST QUESTION '72 F250 2WD
You can punch them both to the passenger side ala 2nd gen lightning. Or hug the inside of the tank.
Or toss the 2nd tank which is the route I took since it was in the way of the RH47 tranny I used.
- mouse
could also run the drivers side like was routed from the factor but have dual pipes down the passenger side. You can then run a dual in dual out muffler like the dynomax 17553 to keep space to a minimal. I had a friends do that on a chevy 1500 and it came out good with out interfering with anything
1993 F250 4X4 ext-cab 6.9 idi
My stock 71 CS 390 option has factory dual exhaust , it has the original hangers and hanger locations. If you want I can get some pictures of the front pipe routing as after the aux fuel tank its pretty straight forward.
I think the cross member might be unique to dual exhaust but you might have to see if your is the same and go from there.
Let me know if you want some photos.
Pics are appreciated!
Thank you!
Thank you!
