Am I missing the kick down lever?
magic bus
Post by magic bus »
This is the way I bought it. It's leaking fluid just sitting. I'm willing to not hook up the kick down but I need to get the nut on to stop the leak. Any thoughts or suggestions on what to use?
Will it work with a washer and a nut or does it have a square cutout to fit over the shaft?
If anybody has an extra kick down lever I'd be happy to pay
I just wanna stop the leak
71 F100 2WD Longbed Sport Custom 390 C6
67 Econoline E100 200 I6 3 on the Tree
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
Ranchero50
Re: Am I missing the kick down lever?
Post by Ranchero50 »
I don't think the lever will stop the link. It shoulders against the shaft. Should be an O ring or two sealing the oil.
magic bus
Post by magic bus »
I found a couple pictures detailing the inner and outer shaft seal. I'm certainly prepared to change the o rings/seals. I just need a couple pieces to finish the assembly?
Ranchero50
Yeah, lever and self locking nut. You'll also need the kick down shaft / linkage.
You didn't mention if it was for your C6 or your C4 but from comparing to my tranny, I'm thinking that photo's of your C6. Here's a couple photos of my linkage on my C4. Probably not identical to yours but should give you a frame of reference. I have a couple more photos if you need them.
