67 truck start problem
Charlie67f100
Post by Charlie67f100 »
Need some help figuring out this start problem my truck won't crank when I turn the key to crank it but if I get out side with the switch to on i can touch the 2 points on the starter silonoid and she will turn over what do yall think is going on in got the truck in park when trying to
Charlie67f100
Re: 67 truck start problem
The silonoid is brand new and the regulator on core su
Charlie67f100
Support is too
Charlie67f100
Figured it out bad neutral safety switch now I gotta figure out the dash lights and low beams don't work could it be a bad headlight switch in the dash
