So I pulled my vacuum modulator and almost all my fluid drained out the hole, I don't believe this is normal? there was also some fluid in my modulator, is this normal?
Thanks
c6 tranny vacuum modulator
- Timd
1969 Ford F100 Custom Cab
302
302
- windhamdw
Re: c6 tranny vacuum modulator
i pulled the vacuum line off mine a few weeks ago and i had no fluid come, if that helps.
- Timd
Thanks
Did you have the truck lifted at an angle?
302
302
- windhamdw
no, it was setting on all four wheels.
- colnago
I had to pull my modulator off last fall. The tranny slowly dripped fluid out, but I doubt if it lost 1/4 cup over an hour. It was parked in my driveway, so at a slight incline. I don't remember if there was any fluid in the modulator itself.
On edit, there was also a plunger of some sort inside the tranny, behind the modulator. While I had the modulator off, this plunger tried to "creep" out of the hole. Could you be missing this plunger, and that's why it drained the tranny of all its fluid?
If you have fluid leaking out of the modulator vacuum nipple then it is time for a new modulator.
1967 F-100 4x4 custom cab.
