What transmission can I run on 67 f100
caya1382
Post by caya1382 »
Can anyone answer a few questions for me I have a 67 f100 with a 302 with a little work on it. But I am having trouble with my transmission. My setup is 302 mild cam 9 inch rearend with c4 with shift kit and I am reving out way to soon and can only do 60 on the hiway. Any recommendations on what rearend gears I need to swap to in order to get the best performance from my engine.
Should I swap the trans to c6 or newer trans ? What trans is the easiest swap ? Rearend is 373 gears
caya1382
Re: What transmission can I run on 67 f100
Post by caya1382 »
HIO Silver
Post by HIO Silver »
3.73? Don't recall that ratio for a Ford 9. A 3.70 is more typical.
Anyhoots, what do you mean by performance of the engine? How do you use the truck? Or how do you want to use it???
IMO, a 302 with 3.50 rear gears is decent for a shortbed and light hauler. However, it's a bit underpowered for a long bed that tows or hauls loads.
If you're review out too soon, then swap to numerically lower gears... 3.50 or 3.25.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
ultraranger
Post by ultraranger »
Keep your gears and install an overdrive transmission.
caya1382
Post by caya1382 »
That's what I wanted to do. But I just completed the whole build and didn't want to be making major changes to the truck do you know what transmission would bolt right up and not alot of changes needed. I read that se of these might work but not sure which is the simplest C6, 4r70w ,fmx,aod. Not sure which is better and don't involve lots of moving mounts and cutting drive shafts etc..
ultraranger
I guess it's somewhat a matter of perspective what's simplest. I'm more interested in what's the best choice. For me, that's the '98 4R70W I'm rebuilding to put in my '69 F100. My current engine is the stock 240 inline six but, I have a '90 Mustang 5.0L EFI engine or a '73 351W I could fuel inject. Whichever one of these engines I install, the 4R70W will be going behind it.
Nitekruizer
Post by Nitekruizer »
A C6 or FMX won't drop your engine RPM any lower than the C4. Your engine RPM would still be the same in D on the highway. You would need an OD trans like the AOD or 4R70W to drop your highway engine revs or keep your C4 and change the rear end gear ratio. I have a manual trans with a 3.54 rear and my engine revs aren't excessive in direct drive (3rd gear) at highway speeds.
eggman918
Post by eggman918 »
Here is a gear vendor OD for a C6 in AZ.
http://phoenix.craigslist.org/evl/pts/5941451849.html
HIO Silver
Behind a SBF?
Manual Transmissions with Overdrive
T-5Z "World Class"
M5R1/M5R2
TKO-500/600
Automatics with Overdrive
E4OD
AOD
AODE/4R70W
IMO.... the AOD is the most low-buck. Here is an article for your information on swapping in an AOD: https://www.hemmings.com/magazine/mus/2 ... 80743.html
crazyhorse
Post by crazyhorse »
Taller tires would help a little.
How tall are your tires?
caya1382
Post by caya1382 »
:) I believe my hunt for a aod will start this weekend.
Thanks for all the help everyone. .. :fr:
Ranchero50
Post by Ranchero50 »
AOD is a really poor design... I'd drop in some 3.25's or even 3.00's and leave the trans alone before going AOD.
ultraranger
The AOD in stock form is a bit lack luster but, with some good clutch discs and a shift kit, the AOD can be made into a good transmission.
The AOD first came out in 1980. However, there were several design flaws to it that Ford didn't address until 1988. So, if you're going to run an AOD, the best versions to get would be from 1988-1993. V-8 versions will have more clutch discs in them than ones behind a six cylinder.
The AODE (electronically-shifted) is the 2nd generation revision of the AOD. The 4R70W (electronically-shifted) is the 3rd generation revision of the AOD. This transmission (4R70W) has way more capabilities over the older AOD.
ThinLizzy13
Post by ThinLizzy13 »
You shouldn't have any problem going 60 with a 3.70ish rear and a v8. Is everything working correctly?
My little 223 will cruise 70 down the highway with a 3.89 rear...
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
