Carb is off currently getting a rebuild. I noticed a lot of grease/gunk sitting on top of the block (below the carb was sitting). I think it is from carb leaking. I would like to clean that up a bit. What have you guys used in the past to clean the engine and engine bay up in the past?
I know to avoid water at electrical connections, wrap carb/distributor in plastic bags. Is that basically it? Get some type of degreaser from Advanced Auto, give a spray, let it sit for a bit, then spray with water to rinse? May repeat if necessary. Maybe even run a few minutes to warm engine to help loosen up grease beforehand? (warm engine=NOT hot engine)
Thinking of going to carwash. (after carb is back on) They normally have warm water (help break up) and only use on the low spray power. NOT FULL BLAST!
cleaning engine?
- Ranchero50
Re: cleaning engine?
A gallon or two of kerosene, a kiddie pool and a box of 1" chip brushes from Harbor Freight. Cram pool between front tires with the back higher than the front. Use brushes and kerosene to loosen, wash all the trash into the pool. Dip out the kerosene and reapply until the engine is clean.
If the paint come off, spray it down with brake clean and respray it.
- 69Ford
Please don't ask how I know this. DO NOT use a petroleum based degreaser above a blacktop driveway. It was a $500 dollar mistake for me. The damage happens right now.
- HIO Silver
Instead of plastic bags, I use aluminum foil to wrap the dizzy. The carb too if it is installed.
Foil molds to the form and is really difficult to blow off with a high pressure washer. Try it, you'll like it.
I use the least caustic emulsifier first... Dawn dishwasing soap and a parts cleaning brush. Then move on to kerosene or odor free mineral spirits. Sometimes I get OCD and pick at the crap with plastic picks, plexiglass, stiff tooth brushes, etc.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I power washed mine a few times and used a cheap engine degreaser probably 5 different times. Scraper for the really thick places. All underneath too.
Kyle
Kyle
You are making much more of this than has to be made. I wash engines all the time and I wrap nothing. I've been doing it for 40 years.
Pete's Ponies
Mustang RUSToration & Performance
I've never wrapped anything either I'm just more cautious around top of the carb and electrical when power washing. It all needs washing tho.
Kyle
Kyle
- MadJoe
I'd have to agree here, I've had my fair share of Fords and none have ever had water related electrical issues the way I've seen with GMs and Dodges over the years. I remember one day I drove my '79 Granada through an enormous puddle that was stalling all the other guy's cars. Well, thankfully my oil rings were bad (who ever thought that'd be something to be thankful for?), because a solid stream of water was shooting out of the tailpipe (and just as much was squeezing into the oil pan). I guess I'm lucky it didn't hydro-lock, but that dang distributor never skipped a beat. Did have to change my oil, and eventually the rings gave out completely and smoke-screened a RI State Trooper on RT4 (he approached my window and asked "How'd you even see me back there?"), but never had an issue with spark.PetesPonies wrote:You are making much more of this than has to be made. I wash engines all the time and I wrap nothing. I've been doing it for 40 years.
That said, I'd still probably throw a tin foil coat over my distributor before running a power washer over it.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
I just forgot to tighten my hose.clamp on my fuel line going into.my carb. Bam..motor degreased. Lol. 1 thing less i have to do.
Gotta get the motor.to where it will boil the fuel.if ur brave enough.
I changed that.line so no.more hose.clamps.
Plz dont do this
-d
Plz dont do this
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
