Suggestions for removing old starter on 360 FE?
thefordguy
Post by thefordguy »
Hi, I recall a few years ago trying to remove a starter on a 360 block, and I couldn't get access to the top bolt. I've heard that there is a method some guys have found that allows that bolt to be removed - with an extender on the socket set? The starter on my '72 highboy is on its last legs, so I'm gonna have to finally to this. Any help on this is appreciated.
1969 F250 CS Ranger
1969 E300
Ranchero50
Re: Suggestions for removing old starter on 360 FE?
Post by Ranchero50 »
Stack a bunch of extensions together and go from the front of the engine. Just leave the bottom bolt in until you get the top on out so you aren't fighting the weight of the starter.
thefordguy
thank! i'll go give it a shot.
1969 F250 CS Ranger
1969 E300
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Post by 1970 Hi-Boy »
A half moon wrench ( 1/2"x9/16" box end) will do the trick as well if ya can get your hands on one, I've had one for years now just to deal with various Ford starters.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
tmcalavy
Post by tmcalavy »
Ditto...good socket, at least two extensions and a six-point 1/2 socket. Now crawl under there and get to cussin'.
Kurt Combs
Post by Kurt Combs »
I pulled the starter on my 360 a year or two back and was surprised that the PO hadn't put it back in when replacing the starter. Then I discovered that the top bolt had be broken off in the hole. I put it back with two and it worked just fine.
Kurt
1972 F-250
1972hiboy
Post by 1972hiboy »
I acually keep a special socket/extension tool in my truck for just an occasion. its roughly ten inches long with a swivel 1/2in socket. I put a extension on it and slip it in from the front of the engine between the engine block and motor mount striaght shot to the top bolt. bolts like a dream every time.
Rich
Dont eat yellow snow.....
thefordguy
I got the new starter and in and it works great. what made this particularly difficult is that with the highboy, I had to crawl into the engine compartment and squat on top of the engine. I"m 6' tall so its not an ez task. very tiring!
1969 F250 CS Ranger
1969 E300
BobbyFord
Post by BobbyFord »
The trick is a 6", 3/8" drive extension, 1/2" flex socket and an air ratchet.
70-360fe
Post by 70-360fe »
I use 2 long extensions about 1.5 feet all together. There is a small opening you can snake thur to get at the bolt. You can get at it from the top with a coulpe of long extensions.
MadJoe
Post by MadJoe »
Ranchero50 wrote:Stack a bunch of extensions together and go from the front of the engine. Just leave the bottom bolt in until you get the top on out so you aren't fighting the weight of the starter.
This just worked for me perfectly. It actually took me less than an hour to get the old one out, wash my hands (it was really filthy), and put the new one in because I knew to have a 1/2 socket on a bunch of extensions for the top bolt. Actually, the top one was the easiest to remove, and only slightly harder to install than the other 2 because of this advice. Thanks!
On a side note, it seems I have a bit more of an oil leak than I originally suspected.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
