steering shaft slop
steering shaft slop
My steering shaft has slop vertically...shaft moves up and down if you take the steering wheel in hand and pull on it or push on it. It seems the slop is in the box maybe as the shaft and coupling appear solid. Suggestions?
1968 F100 SWB Flareside, 240-6, 3 speed, 3.70 rear, bone stock and rust free.
- SmokeyBear
Re: steering shaft slop
Take a look at the bracket that mounts the column to the floor, Even if the box were removed, if the lower end of the column was bolted down correctly there would be very little slack.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
72 F-100 Ranger XLT
