Dana 60 Rear axle for 1969 F250 CS 2wd
I have been trying to find the lock plate that goes between the wheel bearing adjusting nut and the locknut. The parts diagram for that axle lists the Dana part number 1124. Cannot find anywhere or anyone that has a replacement part. Need help finding part!
- robroy
Re: Dana 60 Rear axle for 1969 F250 CS 2wd
Maverick1941, I used Napa 635-1100; here's a photo:
Maybe you'd enjoy skimming through this thread (especially the last page): 1972 F250 12"x2.5" Bendix rear drum brake rebuild: advice?.
Thanks for your help. I called Spicer this morning and even they couldn't help. They told me that this was a manufacturer supplied part.
- eggman918
I believe that i got them from either NAPA or car-quest using the Dia. of the spindle threads.
Try Six States Distributors for the lock washers. Part #DA30637. I paid 5.26 each June 2015. they had them in stock in SLC, UT. Six States Dist. are drive line specialists. Good luck.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
69 F250 Explorer
TT & XT500 mc's (6)
