Oil Pan removal
BlackBart48
Oil Pan removal
Post by BlackBart48 »
So I have this 1969 Ford F100 with the 240 CID in it. She's only got 21,000 original miles on her so doesn't get driven nearly enough. Recently the oil light started coming on at an idle. The oil didn't have many miles on it but it was really old so I just changed it. Didn't help. Still have the oil light coming on at idle. I suspect sludge clogging the oil pump intake and I would like to take a look. Before I go start trying to drop the oil pan, can someone tell me if you can actually just unbolt it and remove it as the truck sits or do I need to do some other things first?
Thanks!
HIO Silver
Re: Oil Pan removal
Post by HIO Silver »
IIRC, the pan can be dropped but you'll have to reach in and unbolt the oil pump and pickup tube for the pan to be withdrawn.
BlackBart48
Re: Oil Pan removal
Thank you! I got all the pan bolts out. It's loose but I had to move on to other things. I will hit it again tomorrow. Now I just need to figure out where exactly those pump bolts etc. are. I am starting to worry that its going to be a real pain to get it all back together. Am I right?
Thanks!
Re: Oil Pan removal
There are some very good pictures in this thread of the 300ci 6.
http://www.fordification.com/forum/view ... hp?t=77609
Oil pump is roughly in the middle.
Re: Oil Pan removal
You're better off lifting the engine with a hoist or jacking it up and blocking under the motor mounts. That way you'll have clearance to slide the pan backwards and clear the front crossmember. Removing the oil pump bolts and dropping the pump to get the pan off isn't too bad but putting it all back together that way is a royal pain.
BlackBart48
Re: Oil Pan removal
Thanks for the info everyone. This helps. :-D
hillcountryflt
Re: Oil Pan removal
Post by hillcountryflt »
Seems like I recall you need to lift the engine about the height of a 2x4 to get the clearance necessary to remove the oil pan. I would like to replace the oil pan gasket on my 69 with a 240, but its a big chore for relatively small drip.
One other thing, might consider going to the "modern" oil pan gasket when putting it back together. You will need to grind down the raised edges on the holes (where the bolts go through) on the oil pan to smooth them out, but that rubber gasket with its outer ridge sure seems better than the stock cork gasket. I did this on my 71 after having the engine rebuilt.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
WhitsEnd
Re: Oil Pan removal
Post by WhitsEnd »
Um, did you make sure it's not just the oil pressure sending unit that's gone bad? Probably worth the $5 to change anyway.
8) 1970 F100 Ranger 2WD
:thup: project link: http://www.fordification.com/forum/view ... 22&t=83642
