Door Jam Switch brackets and harness
48prerunner
Post by 48prerunner »
Looking for a set of interior light door jam brackets and Harness. Or any parts or pieces
Ranchero50
Re: Door Jam Switch brackets and harness
Post by Ranchero50 »
The harness is part of the main dash harness so you'll need one of those for you style instrument cluster connection.
Switches are offshore made via DC for $7 if memory serves.
Mach428
Post by Mach428 »
I have a perfect set of brackets, $20 plus $6.80 shipped USPS.
The pin switches can be bought new from NPD. You can make the harness quite easily and tap into the wire going from the light switch to the dome. I did this on mine as you don't see the wires once installed.
Look at the wiring schematic on this site and it will all make sense
48prerunner
Pretty sure the harness just plugs into the plug where the interior dome light plugs in under the dash. just undo that connection and plug into each side of that. I have the switches but would have to buy repop plugs for the end Might take Mach up on his offer if I cant find the whole set up.
48prerunner
Thanks for the replies I ended up buying what I needed on ebay.
