Does anyone have one of these that the piston isn't stuck inside the body? It's for a 1969 f100 2wd with 4 wheel drum brakes. I believe any 67-72 f100, f250, etc will work as long as it's 2wd and 4 wheel drum brakes.
Brake pressure differential valve
- 69f-100
- themoldfords
Re: Brake pressure differential valve
I believe I still have one of these, I cannot verify the condition as the brakes were inop when i got the truck, but you can have it for $5 + s&h.
Tim
____________________________________________________________________
'69 F100 240, 3 spd (used to be column shift), '05 F150 wheels, cougar buckets, Hurst floor shifter, '78 discs, power steering and column
"Your responsibility to be ready for the fight never ends" - James Yeager
- 69f-100
Thank you for responding, but I just got one a couple of weeks ago.themoldfords wrote:I believe I still have one of these, I cannot verify the condition as the brakes were inop when i got the truck, but you can have it for $5 + s&h.
