Transmission ID
willowbilly3
Transmission ID
Post by willowbilly3 »
OK, I'm a stick shift guy so help me out. How do I tell what tranny I have. I originally thought it was a C6 but after I got it out from under the bench, I think it might be an FMX. How do you tell? I haven't rolled it over to ID the pan but it has some ribs on top and I think the pan has a notch out of one corner.
re: Transmission ID
Sounds like a C-6 to me....some of those had those ribs, and also have a notch in the pan:
Does it have a cast-iron or aluminum case? All C-6 trannys have the aluminum case, whereas the FMX is cast-iron. ALso, the C6 case is all one piece....whereas the FMX and C-4 have removeable bellhousings.
binder56jd
re: Transmission ID
Post by binder56jd »
now serving #235
willowbilly3
re: Transmission ID
All aluminum case with integrated bell housing, so it must be a C6. For some reason those ribs made me think FMX.
what ribs? i don't think my c6 has ribs. when you say ribs i think fmx also.
re: Transmission ID
I tried to find a pic of a case with ribs, but I couldn't. Some C6 trannies have 5 or 6 small ribs where the bellhousing and main case sections would meet, right on top, if they were separate pieces. I've had one of those in the past. I know that some folks have had to grind those down for tranny tunnel clearance when swapping those C6's into Mustangs or Fairlanes.
ok i think i have seen those.
re: Transmission ID
I just found these on E-bay and edited them a bit to illustrate the ribs. Not the best angle, but at least you get the visual:
yea that wasn't what i thought he was talking about. i pictured several real close together. thick and taller than that.
