Stilling having problems
Aurelio Landeros
Post by Aurelio Landeros »
it looks like gear oil is leaking from the top of gearbox. clutch fork is still unstable and i have no clue how to fix.... any advice
Aurelio Landeros
1970 f100 240 I6 3.9L 1bl carb 4 speed light duty
blumule
Re: Stilling having problems
Post by blumule »
your going to have to pull your transmission.replace your top access cover gasket. make sure vent hole is not clogged. clutch fork has a spring clip that hooks on inside of bell housing.
