'68 F250 In California and my first rebuild!
Hello from California! This is my first post, although I've been lurking on the site for a while now. I'm currently right in the middle of my first rebuild ever, learning bit by bit along the way. I'm just about to get the block back from the machine shop, so I figured now would be a good time to join up!
'68 F250 Camper Special 2WD FE360 V8
- jimmy828
Re: '68 F250 In California and my first rebuild!
Good Luck in your rebuild. I,ve owned a 68 F250 Camper special that I bought new in June 1968. I also have some part numbers that are not listed in Fordification parts list yet. If I can help, let me know. I live in the Sacramento Calif. area
- HIO Silver
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
- Mancar1
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fireguywtc
Bill
2024 F350 CCSB, darkened bronze
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Okay, so I've got the motor back in the truck, broke in the cam, now it'll start, but it won't idle at all. It's also spitting liquid, unburnt fuel out of the carburetor. It'll still run if I apply throttle, but not very well. Any ideas?
