360, 390 flywheel the same?
76Kroh
Post by 76Kroh »
Long story short I scored a hell of a deal on a 390 for my truck. I currently have a 68 with a 360 and a four speed manual. The 390 is coming out of a 74 with an automatic. My flywheel should work just fine correct?
1968 f100 LB 360 4-speed manual :help:
tnlprt
Re: 360, 390 flywheel the same?
Post by tnlprt »
Same balance
Same bolt pattern
Same everything
Bolt it on and go
Make sure and buy a new pilot bushing for the rear of the 390 crank
76Kroh
Post by 76Kroh »
tnlprt wrote:Same balance
Same bolt pattern
Same everything
Bolt it on and go
Thank you for the info. That's what I thought but I wanted conformation.
