3 speed floor shifter question
bigbluthng
Post by bigbluthng »
is there any adjustment to a floor shifter's side to side motion? the trans engages r,1,2,3 just fine but there is a lot of slop side to side making it difficult going from first to second. trans is a 3 speed manual originally out of a fairlane.
Mach428
Re: 3 speed floor shifter question
Post by Mach428 »
I've never seen a side-to-side adjustment on a shifter. There are bushings that you could possibly replace and restore the original clearances; however, there may be more to the issue. Have you removed the shifter for inspection?
Dave Severson
Post by Dave Severson »
Depends on the brand of shifter, some did have a spring in them. If it becomes warn you could perhaps replace it or maybe add a shim or two in order to limit the side motion a bit. Chances are, the shifter has just been used a lot and is worn out. However, anything is rebuild-able if you have the patience and a bit of creativity in you fabrication skills!!!!! Good luck!
Retired and lovin' it!!!!!
