2WD TO 4WD
tommy6386
2WD TO 4WD
Post by tommy6386 »
here is my plan..I have a 1970 f350 2wd chassis I bought a 1971 f250 4x4 chassis which ended up having 1978 axles and transfer case under it, my question is has anyone done something like this? if so ( or not) what kind of issues do you think I'm going to have converting it? thanks!
HIO Silver
Re: 2WD TO 4WD
Post by HIO Silver »
That's not a plan... that's an idea.
What is the idea any way?... it's not clear. A body swap? Or fit the axles to the 2wd?
Typical issues are the 2wd crossmember and steering. More research to do on your end. Good luck.
tommy6386
Re: 2WD TO 4WD
Post by tommy6386 »
ok to make things more clear.... I have a 1970 f350 2wd chassis that I am putting a 1967 f100 cab and bed on...I bought a 1971 f250 4x4 that rand and drove, frame is trashed, cut up, modified,trash, upon research found that the axles are out of a 1978, I am going to put them on the 1970 chassis, just wondering if any one has converted a 2wd to 4wd with this set up and ideas on how to do it the best..thanks :?
1972hiboy
Re: 2WD TO 4WD
Post by 1972hiboy »
it would be easier to find a 4x4 f250 frame and bolt your 67 body onto it.
Rich
Dont eat yellow snow.....
