302/351W Engine Perches for 2wd F100
JIMO2
Post by JIMO2 »
I currently have a 351W in my 67 f100 2wd on the FE/6cyl engine perches. The engine sits a bit high and the rubber mount studs do not go to the bottom of the slot in the perches when the engine comes to rest, so it has room to move. I had to level the engine out, side to side, when I first got the truck and re-tighten the stud nuts. In the next year or so I plan to do an engine swap, as mine is tired, and figured it may become a great time to remedy the perch situation. I would like to purchase the correct perches as per this link :
http://www.fordification.com/tech/engine-perches.htm
Thank you for any help in the matter,
Jim
Jim
"I love it when a plan comes together"
dsnyder78
Re: 302/351W Engine Perches for 2wd F100
Post by dsnyder78 »
Ill let you know. Im putting a 302 in my 67 and ordering the engine perches from 73- for 351m/400. Ive read somewhere else that these will work.
'67 swb - 302, 8.8
JIMO2
Post by JIMO2 »
Yes sir, thanks. This may be what you read:
I was hoping someone here was cutting up a 73-79 truck and would spare them
Jim
Jim
