driveshaft vibration
Rockybar
Post by Rockybar »
Been hunting a noise, bought 2 u-joints, replaced them both.
Now my noise is a serious vibration at low speed, seems to go away up high speeds.
What could I have messed up?
thanks
1967 F100
390, 3 spd on floor
(my first ford, so have patience, I'm a Chevy guy)
Re: driveshaft vibration
Single or dual driveshafts? Dual driveshafts need to be phased. (Ujoints lined up). If single unbolt shaft and turn it half aroynd and put back in.
hillcountryflt
Post by hillcountryflt »
Please explain "phased" in reference to replacing u-joints on a long-bed pickup. I have one with the split drive shaft and would be interested in this as I have yet to replace my u-joints on my 69 F100.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
u joint caps should line up on both shafts. Be inline with each other.
fordchris47
Post by fordchris47 »
carrier bearing could be broke that's what happened to me, the rubber around the bearing cracked had vibrations at low speed
72' f100, 390, performer rpm intake, performer rpm heads, summit cam 276 dur 533 lift, holley 750, flotech headers, c6, 350 rear end, electronic ignition and msd box.
mustang68 ranger71
Post by mustang68 ranger71 »
Thank you fordman, I just acquired a 71 camper special 390 that i a bit of a hot rod. The u joints are going to get replaced soon along with the carrier bearing. That is good to know about the phasing. i would have been chasing that for ever.
