Also, the passenger side wheel is dragging in one spot when I try adjusting the brakes. When I turn it about an inch or so, it frees up and free wheels until it reaches the same spot again. So I'm not real sure where to set the brake adjustment.
I even took the brakes apart and put them back together again to be sure they were installed and seated right.
Would this be a drum or shoe problem ?
