Instrument cluster Female electrical pin
flyboy2610
Post by flyboy2610 »
One of the electrical pins on the plug of the F600 dash cluster that I purchased (the fuel gauge wire) had the wire cut off right at the pin. I got the pin out of the plastic connector plug, but can't find a new pin of the correct size. As close as I can tell, the OD of the pin is .100 and the ID is .080, measured with calipers. If any body has one of these pins (female), I could really use one. The pins that I have found don't match the dimensions of mine, and they have two prongs on the sides, whereas mine has one prong on the back. They also come in lots of 100 pins, and I'd never use that many!
If anyone can help, it would be appreciated.
69Ford
Re: Instrument cluster Female electrical pin
Post by 69Ford »
Is this what you need PM me and let me know
flyboy2610
69Ford, I sent you a PM.
69Ford
Post by 69Ford »
This is what I have. sent a PM reply Thanks
