1971 F100 Steering Wheel Installation
schrankage
Post by schrankage »
We tried to replace this steering wheel and when we put the new one on, it was sticking out a little too much. Does anyone know what to adjust/how to fix this issue?
Linked is an imgur album.
http://imgur.com/a/0PXNm
91Bear
Re: 1971 F100 Steering Wheel Installation
Post by 91Bear »
Yep. Loosen the bolts and pull the column up to meet the wheel.
schrankage
91Bear wrote:Yep. Loosen the bolts and pull the column up to meet the wheel.
Which bolts? The ones under the hood on the steering column? Or the ones inside the cab?
schrankage
No one knows?
The one's inside the cab, under the dash. The bracket is slotted for that reason. Once you get it where you want it, take a look in the engine bay, at the bottom of your column, and make sure the bearing keeper bracket is pushed up against the lower column bearing. The steering shaft is the fixed component and the column housing can slide up and down as needed.
schrankage
If you loosen the 2 bolts under the steering column where the slots are, should you then be able to slide the column up'? The reason I am asking is that I loosened the 2 bolts and the column was still tight. Might I have to loosen something at the firewall also. There is a rubber pad around the bottom at the firewall that is hard. I am afraid that if I disturb it it will break in pieces. The owner of the vehicle didn't want it broken. I even hit the column with a hammer to get it to come up and it wouldn't budge. Its like there's something at the firewall holding it. Do you have any suggestions?
canadiancobra
Post by canadiancobra »
My column also has a clamp holding the steering column housing to the firewall bracket.
Hawkrod
Post by Hawkrod »
You do not adjust the column to wheel clearance by moving the column mount. You adjust the clearance by adjusting the clamp on the inner shaft below the lower bearing. Have someone in the truck push the wheel into the column while you loosen the clamp and slide it up against the bearing and tighten it down. You may have too much clearance because of a failed lower bearing. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
