2 Things.
1. What do I need to change my rear leafs? My Grandfather decided that my truck, which he wanted to be a pleasure rider, needed 1 ton springs so I might at well we riding on a 2x4 with those and the bucket seats in the truck. FYI, if anyone if looking for a pair they have the original hardware and were done in white leather and I will be selling them when I find a bench seat.
2. Could I use the Dana 60 from a Chevy? We have an old 87 plow truck and the frames days are numbered, to many Maine winters will do that to anything. I figure a Dana's a Dana. And disc brakes would be mighty nice.
Leaf Springs
Leaf Springs
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
2009 Scion XB Auto
- tbone6
Re: Leaf Springs
Hello, I can't help with the questions, but when you are ready I would be interested in the bucket seats. Just drop me a message.
Good luck!
Good luck!
t6
1972 F100
1972 F100
Re: Leaf Springs
I am assuming you Ford is a 4x4? Although still a Dana, GM and Ford typically have different alignment of drive shafts from which side the differential is on ( I believe Ford is on the drivers side and GM's I believe the passengers side, but not certain). I'd do a bit of eye balling to check it out before progressing any further
And are you inquiring on how hard it is to change the rear springs? Or a source or price?
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Re: Leaf Springs
How hard is it to do. I have 3/4 ton ones to put in. Do I need to replace the rubber part where the bolts go through?
2009 Scion XB Auto
2009 Scion XB Auto
- tbone6
Re: Leaf Springs
It is pretty easy to change out the springs, just be careful and take the weight off. I would replace the rubber with polyurethane bushings. They are not expensive, and while the springs are out you might as well.Flightman91 wrote:How hard is it to do. I have 3/4 ton ones to put in. Do I need to replace the rubber part where the bolts go through?
t6
1972 F100
1972 F100
- HIO Silver
Re: Leaf Springs
Deleted.. my bad.tbone6 wrote:Hello, I can't help with the questions, but when you are ready I would be interested in the bucket seats. Just drop me a message.
Good luck!
Re: Leaf Springs
Sorry to dig up an old post, but in regards to the leaf swapping, I'm wanting to so the opposite, but before mucking in the muddy wrecking yards here, is there a difference in width? I have a half ton with completely shot leafs, and am thinking of going to 3/4t, or maybe even 1t leafs.
Ford came first, and the Dodge Bothers made the motors for Ford. Who are these lil boys and their "Bow-Ties?"
- guhfluh
Re: Leaf Springs
F100 and F250 2wd leaf springs are 2-1/4" wide from 67-72 only. The through bolts on F250 spring eyes is larger than F100 springs.
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
