1972 highboy transfer case shift pattern
hi all.i just bought my 72 hiboy and I was wondering if someone could please tell me what the transfer case shift pattern is.when I got the truck it don't not have the 4x4 knob on it.please help.thank you
Re: 1972 highboy transfer case shift pattern
Off the top of my head, as long as you have what i have (divorced Dana24)
should be 4L all the way forward then N, then 2wd, then 4H, in a pull towards rear pattern. Hope this helps an im right, i know that i never look i just grab an pull hard for 4H
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
thank u that was it .
Good!
-Mike-
ECV 1849
ECV 1849
- 1 Crummyshooter
It doesn't show anywhere but there is also a 2L between 4L and N. Comes in handy if your hubs are in and you want a lower gear on pavement. Backing a trailer into a tough spot.
Due to the high cost of ammunition, you can no longer expect a warning shot.
When someone was beating on my door hollering "Alcohol, Tobacco, and Firearms", I naturally assumed it was a delivery.
