Looking for lower front park lamps in the grille for 67to 69
straight-shot
Post by straight-shot »
As the title says I'm looking for the lower front park lamps in the grille for 67to 69.
At a minimum I need the lenses and the Passenger side light housing. But I would take a full set.
Thanks!
68RGR
Re: Looking for lower front park lamps in the grille for 67to 69
Post by 68RGR »
Todd - Wish I had known you needed them two weeks ago. Went to a wrecking yard that had a couple of our trucks. Don't recall if they had parking light parts but I will check the next time I'm there. Maybe 2 weeks from today.
Bill
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
straight-shot
Thanks Bill!
If you happen across some please let me know! I am putting a totally straight 69 grille on my 70 and the only thing it needs is the lights. I got it cheap too! :hd:
Did you get the moulding pics that I sent?
djjsc
Lower front park lamps in the grille for 67to 69
Post by djjsc »
straight-shot wrote:As the title says I'm looking for the lower front park lamps in the grille for 67to 69.
Thanks!
A '67 set here. Appears park lamp housing is part of the grille........ correct? Image won't paste; direct is djjsc(at)juno(dot)com
"If you're not liberal at 20, you have no heart... if you're not conservative by 30, you have no brain." Winston Spencer Churchill
straight-shot
Found some!
Thanks!
