http://www.ebay.com/itm/Ford-F100-1-2-t ... 75&vxp=mtr
I orderd a set of anodized caliper adapters and read quickly through the instructions. It seems straight forward with the following notes:
- Take the hubs to a machinist and have the hub flange turned down to fit inside the rotor with 0.010 clearance. This centers the rotor to the hub.
- Lug studs need to be pressed out and replaced with studs 0.25" longer than stock.
- The rotor must sit flush to the hub face. The back of the lug holes may need to be countersunk.
Rotors, 76-93 F150 4x4 (front) - NAPA 4885611, Wagner BD60441, Raybestos 6048R
Caliper, LH - 90-02 Astro Van AWD- NAPA SE4850, Wagner TQM25002, Raybestos RC4418
Caliper, RH - 90-02 Astro Van AWD- NAPA SE4851, Wagner TQM25003, Raybestos RC4417
Brake Hose, LH (front) - 82-83 Pontiac Firebird- NAPA UP38102, Wagner F106368, Raybestos BH38102
Brake Hose, RH (front) - 82-83 Pontiac Firebird- NAPA UP38103, Wagner F106369, Raybestos BH38103
Banjo Bolts (Front, Qty 2 included), 82-83 Pontiac Firebird - NAPA 82703, Dorman PN 13940
Two cotter pins, two hose clips (included). You will need a prop valve.
Use the PNs above for crossover applications. For example, the calipers can be sourced from 95-97 half- and one-ton GM trucks and SUVs.
