steering column housing
- 69f-100
I have a 69 f100 2wd automatic with power steering, does anyone have a steering column housing that they would sell? This column should measure to be 28 1/16 inches long to be the correct one for an automatic with power steering.
Re: steering column housing
does it need to be a p/s a/m column, or will any work?
1967 F100 52,000 orig miles- current CV swap and drop, shortbed conv
4 '65-'66 mustangs
2 '65 Galaxies
'59 Fairlane
'48 F1
'39 Ford Sedan
'65 Tiger (the real deal)
1barn full of Ford parts
1 VERY understanding wife!!!
4 '65-'66 mustangs
2 '65 Galaxies
'59 Fairlane
'48 F1
'39 Ford Sedan
- 69f-100
Needs to be p/s and a/m column.knucklejs wrote:does it need to be a p/s a/m column, or will any work?
- 69f-100
still looking for one of these if anyone has one.
i have it. how soon do you need one? just pay the shipping on it.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
here is a pic of the one i have, it is 30.5" long. I kmow there is some different lengths out there.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- 69f-100
Crap Bill, It has to be 28 1/16 long for it to be for a automatic with power steering. According to the information on this forum the one you have is for manual steering. Mine is an automatic with p/s and it measures 28 1/16 long just like it says it should on here.Bill Ramsey wrote:here is a pic of the one i have, it is 30.5" long. I kmow there is some different lengths out there.
- 69f-100
If you look in the tech/tutorials for "how to shorten your manual steering-column" it shows the different lengths per application. Scroll down to "Sectioning the Shifter Tube, Main Shaft and Main Housing" and look in the blue box for "column housing" power steering- 28 1/16 and manual steering- 30 7/16.
it is for a power steering and automatic truck, BUT, it was a Bendix (power steering) box on the truck. back to drawing board, i guess.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- 69f-100
I guess, I've been looking for one for a while now. Thanks for checking for me though.Bill Ramsey wrote:it is for a power steering and automatic truck, BUT, it was a Bendix (power steering) box on the truck. back to drawing board, i guess.
if you really need one i can probably find it. these trucks are plentiful in the yards around here.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- 69f-100
If you happen to come across one that would be great.Bill Ramsey wrote:if you really need one i can probably find it. these trucks are plentiful in the yards around here.
- 69f-100
I'm no longer looking, I found one.
i want to hijack this thread. I'm doing the ms/ps steering column shortening. I'm trying to put it all back together. I"m at the point where I need to bolt the turn signal assembly onto the housing. It doesn't seem to want to seat all the way. I've triple checked my lengths. Both the shifter tube and the outer housing are exactly as the chart specifies. It looks to my eye that I need to cut the shift tube about 3/4" shorter than specified to get the blinker assembly close enough to the housing to "engage" it and bolt it down.
Anyone else had this problem? Am I missing something?
68 F-250 Camper Special '94 Cummins Diesel engine
http://www.fordification.com/galleries/ ... ?cat=10325
