hi everybody, so i spent about 5 hour at the junk yard taking parts off a 1977 f100 for my 1969 f100 swb took power steering,pump,brackets,pulleys also complete i beams with spindles and everything that attaches to i beam except for shocks,line brackets and distribution valve no brake lines or hoses since i,m going to buy them new.
my question is can i use the manual master cylinder and just add a power booster or do i need a complete set? didn't take that off because it look very rusty and not in good shape. thank you for the help
question on master cylinder
- bluef250
Re: question on master cylinder
There is a proportioning valve needed for the disc brakes. I also believe you need the master cylinder.
- HIO Silver
You'll need a disc-specific MC. Calipers require more fluid to operate than wheel cylinders -that's why the rear reservoir in disc/drum systems has more volume.
You'll need the line brackets from the Dentside...70 & earlier rigs aren't compatible because the hoses are oriented differently.
Some pics of my 70 build to visualize...
78 MC and booster with a Wilwood prop valve on a custom bracket:
Custom lines:
Early bracket vs the later bracket (mocked-up);
Make every piece a work of art:
Custom lines:
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I also got the proportional valve and hose brackets just need the master cylinder and booster. thank you for the answers by the way this is a great place to get some good knowledge on the f100 i:am very happy I found this web page. once again thanks for the help and I will be uploading some picture of the progress soon. GOD bless
