Rear Axle Swap from Dentside
I am thinking of taking the complete rear end out of my donor 75 and putting it into my 72. I know the 75 is wider and I need to cut and reweld the mounts for the leaf springs. I am thinking the wider stance will give me a little more stability and nicer ride. Anyone else out there done this? Better to get some advice now than when I am elbow deep into it!
- ForingaMex
Re: Rear Axle Swap from Dentside
I did it to my truck but can't comment on the stability issue. I never drove my truck with the original rear end in it. I did it purely for looks.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
- HIO Silver
That's alot to do for two inches or so of track width. A wider set of rear tires would likely provide the "stability" yer looking for. And a better option for overall handling characteristics would be to install front and rear sway bars.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I am doing it to mine but getting a little creative with it. I am putting new housing ends on it so I can narrow it 1.2 inches. That way I will get the "look" I want and still use the 31 spline axles
Build thread:
http://www.ford-trucks.com/forums/12052 ... build.html
I did this swap to fit my wheels, did the spring perches as you mentioned, also since my truck is lowered I put the axle on top of the springs.Rayjay69 wrote:I am thinking of taking the complete rear end out of my donor 75 and putting it into my 72. I know the 75 is wider and I need to cut and reweld the mounts for the leaf springs. I am thinking the wider stance will give me a little more stability and nicer ride. Anyone else out there done this? Better to get some advice now than when I am elbow deep into it!
I had to move the shock mounts as well, they were where the perches needed to be. I cant comment on the wider stance or ride, I changed a few different things that I thought would help, didnt notice much but I mostly just go straight...
Any pics of your truck?70shortwide wrote:I did this swap to fit my wheels, did the spring perches as you mentioned, also since my truck is lowered I put the axle on top of the springs.Rayjay69 wrote:I am thinking of taking the complete rear end out of my donor 75 and putting it into my 72. I know the 75 is wider and I need to cut and reweld the mounts for the leaf springs. I am thinking the wider stance will give me a little more stability and nicer ride. Anyone else out there done this? Better to get some advice now than when I am elbow deep into it!
Build thread:
