T-18 to T-170/RTS/TOD swap. Speedo cable and gear?
guhfluh
Post by guhfluh »
I'm in the process of swapping my 240 and T-18 trans for a 300 and T-170/RTS/TOD trans out of an 85 F150. The speedometer cable for the '85 has a clip on the end that goes into the speedometer, where my 1967 cable has a nut that screws onto the speedometer. I haven't yet tried to fit my 1967's cable into the T-170 trans yet, but I expect that end not to be the same either, as well as the gear.
Does any one know of a source for the correct cable and gear for this application?
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
ForingaMex
Re: T-18 to T-170/RTS/TOD swap. Speedo cable and gear?
Post by ForingaMex »
There is a vendor on Ebay that makes speedometer cable to your specifications including whatever ends you need on there. I can't vouch for quality or anything since I haven't tried it, just seen it when doing a search.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
