T-18 trans
T-18 trans
The 300 6 I picked up has a T-18 trans mated to - good or bad trans?
- mrtleavitt
Re: T-18 trans
The T-18 is a good, strong tranny. It has a low 1st gear that will only be used for towing. In normal, every day driving you will start in 2nd gear. These things are pretty bulletproof in my experience. The T-18 is a very common transmission in ford trucks from the 1960's, 70's and 80's.
Here's a good link that will tell you more about it.
http://www.novak-adapt.com/knowledge/t18_t19.htm
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
Re: T-18 trans
They are a tough truck transmission. I have one in a 79 F150 with 400,000 miles on it and the truck was purchased new by my father. Only a couple of minor issues over that time. Replaced a couple of reverse detent springs, a plastic shoe on a shifter fork, and the input shaft seal. I run Shell 80W90 gear oil in it and change it every 60,000 miles. Still working great. They do shift like a truck and not a sports car. Long throws and because of that shifting is slow. Don't expect to be able to demonstrate your truck's performance ability with a T-18.
Re: T-18 trans
yea I understand . I think i will try and sell this one I don't think it would work out for my 17 year old son
Re: T-18 trans
sounds perfect for a 17 year old... its almost impossible to do any sort of drag racing with a T-18
