to shorten or lengthen. ..that's the question
Replaced the 390/3 speed with a 5.0 5 speed, have a long bed 68 Ranger, wondering what's the best route, shorten the short driveshaft (don't know the correct term) or extend the long shaft and have a single drive shaft......whats the best route?
"Ashes to ashes, dust to dust, if it wasn't for chevy's our tools would rust".
- HIO Silver
Re: to shorten or lengthen. ..that's the question
The best course to take is to shorten the shorter of the two driveshafts.
shorten the front half,otherwise you'll have to move the mount for the steady bearing
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
- averagef250
If it's under 5 feet use a single, over 5 ft use two piece.
You can use single over 5', but it's less than ideal and can be really bad if the driveline shop uses crappy tube.
