Clutch assembly bearing upgrade and conversion to cable. Also added a Mustang neutral safety/cruise switch.
Will need some 5/8" dia rod, some 1" rod, two 5/8" flat washers, some schedule 40 1 1/2" pipe (1 3/8" id), two 5/8" ID/ 1 3/8" OD bearings with external snap ring. These can be found on ebay cheap. A Fox Mustang aftermarket quadrant. Some flat stock and 1/2" rod.
EDIT: Forgot. Also need a 3/8" flat washer, drilled to 5/8" ID. This spaces the clutch arm away from the bearing. It goes on first during assembly.
Drill the pivot hole on the quadrant to 5/8" id, make the shaft extender and spacer per below. I'm not the greatest explainer as most of what I do is on the fly... But everyone gets pictures.
Knock out the original "bearings" from the pedal mount.
Bearings are 5/8" ID/1 3/8" OD with external snap ring. Bearing rings are .310" thick.
Weld rings on center on both sides.
Weld 5/8" flat washers as spacers on the inside.
Blasted the parts, painting.. You can see the extended clutch shaft.
Modified clutch arm. Extended to catch quadrant, 1/2" dia rod/stud.
Spacer for extended shaft. Shaft extension 3 3/4" drill and tapped to thread on the original shaft, welded with flats matching original shaft. Either make from scratch or from second clutch pedal. Spacer is 2 1/2" long.
Antisieze lube on original plastic brake pedal bushings.
Completed pedal assembly.
Drilled and tapped the arm for a 1/4" 20 bolt to act as a pickup point. Drilled the housing for a 3/8" 1 1/4" bolt and two nuts for a clutch stop. Fitted a Mustang neutral safety/cruise switch.
I'm using a firewall adjuster, pretty self explanatory...
Clutch pedal bearing upgrade and cable conversion,
- SATURN5
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
Re: Clutch pedal bearing upgrade and cable conversion
Excellent write.up! Thanks, Bob.
- SATURN5
Thanks Randy!
Bob
That's frickin' cool. Nicely done.
or, money.
or, money.
- tbone6
