Help
danr
Help
Post by danr »
Im changing from a 3 speed to an np435 4 speed and need to know if it will use the same clutch? I asked parts store and they looked at me like I was retarded , maybe I am but I still need to know if these will use the same clutch . The spline looks different but both are 1 1/16 and 10 spline any info would sure be appreciated.
ToughOldFord
Re: Help
Post by ToughOldFord »
I'd guess it's the same clutch. I base this on looking your truck up on RockAuto's website and then viewing clutch options. They show no distinction between the transmission, the clutches are based on "manual" transmission applications.
To be sure just slide the disc you have over the spines of both transmissions.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
flyboy2610
Re: Help
Post by flyboy2610 »
Most people at a parts store only know how to look up something on a computer. (Which isn't always right anyway.)
Art
Re: Help
Post by Art »
Same clutch as long as you are using pick-up truck parts. Did that swap myself many years ago.
Medium duty trucks (F500+) used a bigger trans input shaft.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
danr
Re: Help
Post by danr »
Thanks for your help!!! :woohoo:
