C5 Selector Shaft
C5 Selector Shaft
I have a C5 that has just been rebuilt, noticed the trans was leaking at the selector shaft. Did some research and this seems to be a pretty common thing. Jumped under the truck to take a look and the first think I noticed was the selector linkage has a home made job. Straightened it out has much as possible but leak is still there. While under the truck I noticed there was a pretty good amount of play in the selector shaft itself. I could pull on the shaft enough and actually see the O-ring without even removing the nut. My first thought here is that something is missing, a washer or something because the O-ring has nothing to seal against. Decided to put in a washer, deal is though I can't tighten it down too much or the trans will not shift correctly. The washer seems to have slowed the leak some and removed a lot of the play but the leak is still there. So basically the selector shaft has a washer, linkage arm (square notched hole) and the retaining nut. Should there be some kind of linkage adapter to hold the O-ring inside the housing? Also, is there a lip seal on the inside of the pan? My guess would be that the O-ring is just to keep dirt and sand from getting in from the outside and there should be a some kind of lip seal holding the fluid on the inside. Did some research and it seems like a lot of shops fail to replace that lip seal which might be my biggest issue right now.
Re: C5 Selector Shaft
It sounds to me that someone has installed the wrong shaft. What are the numbers on yours?
Not sure but will check the numbers. Trans is out of an 84-85 Ranger. Think I will just drop the pan, take the valve body and shaft out replace the seal and O-ring. Could be the shaft is worn out and has to much play which I should be able to tell once I drop the pan.
The trans linkage was a home made deal so I order a new Lokar linkage kit. Trans jumped into reverse on me because the linkage has to much play. Not really a good thing when your under the hood.
- BobbyFord
There should be a number on the outside flat part of the selector lever.
You could probably swap in a factory, C4 selector shaft and linkage and have a stock operating linkage.
Thanks for the info, I will see if I can find a C4 selector shaft.
I ended up going to the parts store and finding a thicker O-Ring which stopped the leak.
