overdrive relay interchange
67 ford f100s rule
Post by 67 ford f100s rule »
does anyone know if there is a relay i can buy to replace the original overdrive relay in my 70? Buying a new exact replacement for 126 dollars is a little high for that relay.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
