Hey y'all!!
I was replacing my u joints with a matched pair from Advance when I noticed, after I got it pressed in, that the rear of the shaft takes a smaller size u joint than the front. Not in bearing O.D., but in overall length. It is about an 1/8 or 3/16 inch smaller. Can not locate the correct size. Are they supposed to be the same or different?
different size u joints
- WarEagle
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
- Art
Re: different size u joints
Most of the bigger joints used on these trucks are Spicer #1330 while the smaller joints are 1310. There is also a conversion joint out there to convert 1310 to 1330.
Over 40+ years, transmissions, axles, and driveshafts can get switched around and quite interesting.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
