reasons not to buy a 70 swb custom?
grues
Post by grues »
Hello all,
I'm new here so please bear with me. I'm going to look at a 1970 swb custom that a co-worker has this week end. he has had it for a number of years with the last 3-4 setting but started regularly.My question is this what are the most rust prone areas of these trucks. what should I look for in the areas of body and frame that would be a reason to steer clear. Thanks for your time
blue68
re: reasons not to buy a 70 swb custom?
Post by blue68 »
grues, Here are some areas to look at:
1.) Lay down and look under the truck at the floor pans
2.) Open the door(s) and look at the bottm of them, and edges
3.) Look at the Cab mounts (important)
4.) Open the tailgate and check the gate bushings.
5.) Open the hood and check the inner/outter corners of the hood.
6.)Check the area above the drip rail.
7.) Check cab corners.
8.) Check bed floor. (under and on top)
9.) Check along the bottom molding of the whoel truck
10.) 67-72's like to rust aroung the welds on the body. Check there.
11.) If the truck has moldings, it's probably rusted under there too from trash build up.
Theres many more places to check, but those are the most significant.
Oh yeah, these are not "reasons to steer clear", just rust prone areas. Most ALL trucks of this age have rust somewhere on them.
grues
Post by grues »
i can't look at the truck this weekend but i talked to the guy and he said that the worst thing about the truck is the driver side cab mount. how hard is that to replace? hopefully next weekend ill see it and know more thanks
that depends on how bad it is. if the floor is also rotten you will have to fix that to. in order for the cabmount to be welded in.
oldfordnut
Post by oldfordnut »
the main thing is if thats the truck you want and its a good price shoot for it man all the replacment sheet metal isn't that much just my opinion cuz i have missed many chances that i regret
bluef250
Post by bluef250 »
Note: If the engine has not been run for long periods during the lay up, the valve train will tend to varnish from fuel. Then when run, you may up with damage and a having to do the top end. On the other hand, no problems will occur. Depends on many factors. If truck is in good condition and something that meets your needs or wants, I would buy if the price is reasonable.
71-F-250SC-72-F-250C
Post by 71-F-250SC-72-F-250C »
Did you get it yet?
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
Chasbod
Post by Chasbod »
Also check the front inner fender wells next to the hinges and underneath the battery trays.
If they are rusted, they are easy to replace.
71 F100 302/3.03 Project Truck Underway
