Rumblin
Steeda300
Rumblin
Post by Steeda300 »
Hey guys,
I just recently noticed that when my truck is over speeds of about 50mph it sounds like im intermittently going over a rumble strip. It seems to increase in vibrations as i go faster. What could this be? Also if im at those speeds and I put the car in neutral it seems to go away. Any thoughts? Thanks.
68 F100 2wd
HIO Silver
Re: Rumblin
Post by HIO Silver »
Well, by deduction it's a driveline vibration since, according to your statement, it "seems" to go away in neutral.
YOUR FIRST STEP IS TO DO SOME TROUBLESHOOTING LIKE A REAL TECHNICIAN. I hope posting up wasn't your first step. Have some skin in the game - get on your back, crawl under your rig, and do a visual and wiggle inspection for broken engine mounts; tranny mounts; loose u-joints, broken welds on crossmember, etc.
Rant over. Good luck.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
