newbie C4 question
joebig
newbie C4 question
Post by joebig »
I have a 1969 F100 LWB with a C4 automatic transmission (or that's what the tag tells me) I am planning to put a slide-in popup camper in it. It's about 1000 pounds give or take. It will be below the GVW. Am I playing with fire with the C4 or do you think it can handle it.
Thanks
Thanks,
Joe
Broncobilly66
Re: newbie C4 question
Post by Broncobilly66 »
A C4 has a square pan. C6 has a Texas shaped pan. Should be fine either way as long as you have a large external cooler
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
joebig
Post by joebig »
Yea it's the square pan
Thanks,
Joe
jzjames
Post by jzjames »
bulletproof!
