Front Windshield Removal.
blue68
Post by blue68 »
How do you properly remove a front windshield without busting it?
My dad tells me it's impossible, but he said it jokingly, so i'm confused.
My parts truck has a perfect one, and I'd like to hang on to it.
flyboy2610
re: Front Windshield Removal.
Post by flyboy2610 »
Use a razor blade or utility knife and cut the lip off the inside of the gasket in the cab. Have a friend apply gentle pressure from the inside while you guide the window out.You might also use a hacksaw blade and cut all around the winshield while doing this.
Don't try to remove the windshield without cutting the lip off the gasket. You will almost certainly break the windshield if you try that!
heep70
Post by heep70 »
I went around to outside of the windsheild on my Toyota. Then just reached around the piller and pushed the windshield toward me after it was cut all the way around. Worked out great.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Sharkdance
Post by Sharkdance »
Yup, exactly what flyboy said.
I just removed mine from my doner truck and a sharp razor knife worked well. Dont even think about trying to save the gasket.
Just cut it all the way around from the inside, and gently push the glass out from the inside starting at either one of the top corners. Then work it around till you can just lift it out of the bottom lip in the gasket.
Sharkdance
70 F250 2WD 360/C6
heep70
Post by heep70 »
Do the Ford windshields have the goop between the windshield glass and the gasket?
Greg
Sharkdance
heep70 wrote:Do the Ford windshields have the goop between the windshield glass and the gasket?
Mine just had a glob of it on each corner under the outside lip, between the pinch weld and the gasket.
Sharkdance
70 F250 2WD 360/C6
Chasbod
Post by Chasbod »
71 F100 302/3.03 Project Truck Underway
spartman
Post by spartman »
Great link there Chasbod!
Thanks
blue68
Post by blue68 »
Wow, that is a great link.
Thanks.
qman
Post by qman »
I got my windshield out of a salvage yard and the gasket was the zipper type. All I had to do was remove the zipper parts and everything slid right out. The zipper gasket was in better shape than my original so I used it.
72 F100 2wd 360 C6 Custom w/factory PS.
a zipper type i haven't seen one of those what is it?
qman
Post by qman »
My neighbor called it a zipper so I doubt that's its technical name. There's a groove in the outside of the gasket and a round rubber strip sits in it. The round rubber thing is about as big around as a pencil. I removed it and then the windshield slid right out. I think it was the last thing I put in after installing the windshield and what it does is tighten everything up. Go to that link posted by Chasbod and it says that Ford redesigned the gasket in 77-79 models and calls the zipper thingy filler strips. I think I got this one from a 78.
oh ok thats what my 78 had in it too.
kwilson
Post by kwilson »
Havent tried it yet but a few people have told me to use a drill n drill out a space in the rubber then take a piece of piano or guitar srting and cut the gasket out. hopin to try it on my 71 parts trruck next week n will let you all know how it goes
Kevin Wilson
70 f100 custom
71 f100 custom
89 f250 mud truck
70 mustang
86 bronco w/400m
03 f-350
piano wire is good for those windshield that have been urethaned in but you can just use a knife to cut the gasket
