Warner T18 Oil type.
DMiller
Post by DMiller »
Hey there,
I am probably opening a can of worms here. but, here it goes. 1971 F250 4 speed Warner T 18 transmission- what oil should be used? I have 80/90 wt.GL5 rated oil in it now, it is my understanding that this GL5 oil may cause corrosion in the gear box. 50 wt. is factory recommended, but I had no luck finding 50wt. gear oil. Valvoline makes a 50 wt. VR1 racing oil, is this what I should be using? Please clear this up for me if possible, thanks.
Nothing better than an old truck...
71 F250 Custom
92 Chevy Z71
Canuck
Re: Warner T18 Oil type.
Post by Canuck »
Nothing wrong with what you have in there now but in a cold climate, shifting is stiff until it warms up. I've hear that some put 50wt motor oil in their T-18 but I wouldn't do that. Motor oil contains detergents that suspends particulate in the oil (so it can be carried to the oil filter for removal). In a gearbox, you obviously don't want that.
1974 F-350 Dually Flatbed with a '300 I6
Calfdemon
Post by Calfdemon »
I did quite a bit of reading on this topic recently when I was working on a T-18 for my friend's truck. 80/90 seems to be the most popular oil to use and this was coming from a lot of Jeep sights where that trans is very popular among rock climbers. There have been people running 80/90 in them for many years without any problems, so I think it is safe to go with that. As the previous poster said, other than the 80/90, some people put in 50 for colder climates so they can shift faster. But in warmer climates, 80/90 is all the T-18 needs.
-Rich
Current toys -
69 Ford F350 Crew Cab - 460 / C6 - http://i253.photobucket.com/albums/hh67 ... lqgskp.jpg
31 Ford Vicky - 1955 270 Red Ram Hemi / 4 speed - http://i253.photobucket.com/albums/hh67 ... bsibvn.jpg
Former toys -
67 Pontiac Firebird 400 convertible (sold 9/13) - http://i253.photobucket.com/albums/hh67 ... bird-1.jpg
67 Ford Fairlane GT - 390 / 4 speed (sold 7/15) - http://i253.photobucket.com/albums/hh67 ... c5hu8z.jpg
DMiller
Post by DMiller »
Thanks Guys,
I will stick with 80/90 wt. thanks for the info.
71 F250 Custom
92 Chevy Z71
